Help Pls
hey guys so my car has developed a problem starting fuel filter changed full tank of diesel gd glow plugs put diesel cleaner in to it wont start unless started with break cleaner sprayed into the intake. maybe i have sticky stop solenoid as other day turned ignetion off and engine still ran ????? can the solenoid be taken out and cleaned ????
I'm more worried about the car still running after you turned it off. Have you checked the oil level lately? Any excessive smoke once started?
loads of black smoke coming out out it turbo pipes are kegged in oil and no aint checked the oil level will be doing that tommorrow as ive been told it could be running on the engine oil
I wouldn't rule it oot mate, it's exactly what I'm fearing
oil level is fine had it plugged into diagnostic fuel pressure 45 psi and apparently it needs to be 250 im puzzled with this car had tank off cleaned reservar and new filter diesel cleaner put in still the same now im thinking do i buy some new injectors maybe this could be my problem also car making rattling noise from tappets at certain revs never done this before
Rather than change any parts and guess at it, I think it would be strongly advised to get it recovered to a local diesel specialist and let them have a look over it.
We could all guess parts they it might be but without seeing the car in person it's going to be very difficult and could end up costly to just guess.
Sorry to sound blunt mate but I think it's a wise move.
