Microcat Request
Could somebody with Microcat do me a favour?
I'm trying to find out if there's a part number for a sealing strip.
The part in question is around the top of the front fog light housing.
It's about 50cm long (give or take) and about a 5mm square cross section. I've found a potential replacement on ebay, but the seller reckons it's only 30cm long. And the part numbers on the label aren't yielding any results
I just checked and its not listed as far as I can see
one thing tho, the fog light housing is only about 30 cms across the top..
Thought as much!!
The strip extends down each side and stops just on the bottom - a little shy of 50cm in length.
Might just order 4 of the strips and use 2 per side - only a slight trim lol
