Airbag Warning Light
Hi I've had the airbag warning light on constantly on my dash for a few months. It started after I had a battery collapse, got a new battery installed it and the light came on , first thing someone told me was to change the airbag module as I had tried to jump the car with the old battery in then I tried to use a tractor battery booster to get it to go, the bloke thought I may of fried the module. So I changed the module but the light still came on. Next thing I was told was to check the connectors under front seats but I don't appear to have any, I have taken of the bottom of the seat to check. Is there anything else I can try to do to get rid of this warning light ?
when you first turn the ignition on does the light flash ? if it does it may be flashing a code number,if it does not you will have to get the codes read to find out what it causing the problem.
