Engine Issue?
So my fiesta mk7 59 plate has developed an annoying 'squeal' at around 2000 to 2300rpm! Above or below this when accelerating its not there and doesn't happen when slowing down. Also doesn't happen when not in gear!
Do I look at a belt / pulley issue? Maybe a transmission related issue? Happens in 2nd / 3rd / 4th / 5th in the same RPM range
It's only just ticked over to 52000 miles!
Is there anything else I should check before I book it in?
I think I have the same issue as you. I posted about it here along with a short sound clip:
http://www.fordownersclub.com/forums/topic/63298-strange-high-pitch-whistlewhine-when-accelerating/
Is this the same kind of noise you get?
My car is also a 59 plate Mk7 and has 51,000 miles so sounds pretty similar.
I haven't got a solution yet but it is on my to-do list to take it in to the garage to find the answer once and for all! Cheers :)
Edit: Mine is a petrol 2009 mk7 1.25 Zetec Fiesta
Hows about you give us a clue what engine you have , petrol/diesel size then we may have others with same fault that was fixable?
Oops haha! The most important bit! As above its a 1.25 petrol!
I have 58 plate mk7 fiesta, mine is a bit more high pitched than normal sort of like a whistle in lower gears, especially when its freezing out. I think it's just the weather as i had my car in the garage for something different the other week and nothing was picked up on test drive to do with the engine.
  • 5 months later...
th_8DC36ED9-39BA-48D9-8569-7C1BE2B4B04B_
Finally got around to this! I'll upload the second vid soon
To be clear it's had a new timing kit / belt / new aux belt / water pump
My impression is it's the exhaust!
And the second
th_1ED35E55-D750-4C33-BD79-66AFF7FBD2F8_
So I finally braved this out and got to the bottom of the problem
1 new rear engine mount / custom flexi part of the exhaust and front resonator gone
