Newbie With Focus! Please Help
Focus Mk 2.5 Titanium
Hi all
I recently bought a focus mk 2.5 1.8 petrol titanium. It has the Sony radio system but have only discovered that it does not have the bluetooth feature. Having read other thread I was wondering is it a case of buying a bluetooth module and plug and play? ( it seems as though there is a mic fitted where the interior light dome is however there is no voice command button on the remote stalk control)
https://www.google.co.uk/search?q=ford+focus+sony+sound+system&client=ms-android-samsung&espv=1&source=lnms&tbm=isch&sboxchip=Images&sa=X&ei=bTTJVPqUBYKP7AbUuICABw&ved=0CAYQ_AUoAQ&biw=360&bih=567
(I'm hoping the above link shows the radio that I have)
Also I changed the battery, and have lost the global closure function!!
Any ideas?
Any help appreciated
Hi, there are various threads on here for your bluetooth question....not that easy I seem to recall but has been done.
Regarding your global closing, because you disconnected battery, they need resetting, have you a handbook with the card, it explains how to do it in there...
Its something like this
Hold the switch down until the window is all the way down
Release the switch then hold down again for 5 seconds
Press the switch so the window goes all the way up
Release the switch and press it up, again for 5 seconds
The window will now be set for one touch and global opening/closing.
Repeat this procedure for each individual window...
Thanks for the reply gregg, will try the windows when I get a chance!
Tried it, global closure working now! Thanks again....
Now for the bluetooth issue!
