Spark Plug Gaps Ngk Plugs
gap sizes are wrong ngk states 1.3mm thats there figure ford state 1.0mm to prevent burning out coil packs and aid rough idling
I thought that was the case still others may be able to use this
It's a handy guide especially for plug numbers etc
so should it be 1.0 or 1.3 im servicing mine sunday with ngk plugs?
Should try these plugs, really great reviews, obviously don't have to buy from this seller, this is just one I found on eBay, http://pages.ebay.com/link/?nav=item.view&alt=web&id=290822769445
All depends on what engine you have, .7, 1.0, 1.15, 1.3. Diferent gaps , ford plugs come pre gapped.still need checking though before fitting.
if you dont want running issues stick to the basic bosch or ngk the super 4 cause bad idling and have been known to cause lots of issues
Thanks for that didn't know that, what about the ngk ones with the 4 on it, have you heard anything about them, cheers
Not the ngk ones no not heard anything about them the focus ignition system was built by either Bosch or ngk mk1 I used standard ngk plugs iridium I think they were
I will prob grab the iridium ones, when I get a chance saves running in to problems cheers
The ford ones are usually cheaper than say halfords and are rebranded ngk plugs
As above, ford/ ngk , same,
I have a trade card for halfords so shouldn't be that bad there, mate
