Ford Focus Heater Water Inlet Hose
Hi all,
I have a focus from year 2000 with that overheating problem. Its the one where a working thermostat doesn't allow water to return from the radiator. I was told to carry out the modification on the water hoses from Technical Service Bulletin No.005/2001, by fitting the "heater water inlet hose kit", part number 1139359. Problem is its £80! I have plenty of t-pieces and spare coolant hoses around and was thinking of making up a kit myself. Looking at the picture it looks simply like two t-pieces and a piece of hose between them.
Is that all it really is or are there any internal valves or parts inside?
  • 2 years later...
Any joy With your DIY job?
Hi
Yeah I made up a hose myself and it worked a charm immediately. I just followed the original design by trying to match the hose sizes as best I could. Made it up, cut the hoses and fitted it to the engine. Topped up with coolant and on the test run it worked straight away. I didn't fit any restriction in the hoses just left them as they were.
Do it!!! It  really is a doddle!!!
