Will The Stock Head Unit Work Fine With After Market Speakers?
Will it have enough power?
  • 2 months later...
It will work but the power from the built in amp might not get the best from aftermarket speakers especially if you spend a lot of money on high spec speakers.
In general, you'll need to turn it up a bit more with aftermarket speakers. That's fine, unless you already have it turned up pretty high, and then it isn't.
Compare the RMS rating of the headunit and the speakers.. you'll then know if you need a seperate amp.
For example, my headunit provides 70w per channel RMS but my Focals require 75w. For that reason I run an 800w Blaupunkt gta 470 for the speakers and a JL Audio jx500 1d for the sub
