Focus Mk2.5 Ice Warning Not Coming On??
Hi, i noticed the ice warning light in the cluster is not coming on . Tezza checked withthe elm 327 if its ticked on box & its ticked .
Although it shows the outside temperature & it was 1°c this morning so should have lit red snowflake.
Could it be the sensor alone?
Anyone any ideas?
Yunii
1 degree Celsius would be a yellow, not a red. Red is 0 or below. I would start with doing the instrument cluster self test (hold set button, put key in and turn to ig 2) and then do a light check which will illuminate it yellow and red flashing. If it doesn't come on then the fault is in the cluster
Sent from my Gen 1 WAP phone
Hi, yes i know this but it doesnt even show when ign on, on pos 2 show all bulbs.the cluster shows the outside temperature but no ice snowfake red or amber.
When i do cluster self test & that bulb does not illumenate. Does mean the bulb is blown or something?
Can these bulbs or leds be replaced?
Yunii
Have you updated your cluster firmware with ELMconfig at any time?
I had issue with the ice warning not working, was due to the version of ROM512 had been modified to remove the feature.
With mine the light would still illuminate yellow/red when you put the cluster into Test mode
I dont know but tezza did plug elm in a few times so could possibly be .the light does illumenate in cluster test mode. I just tested a minute ago.
So what is the solution to work the feature?
It was working before.
Yunii
troy45
I took a small clip whilst doing a self test mode & i read rom 509
On the information page for HEC in ELMconfig it'll show Initial ROM Level, so you'd be able to see if that was also ROM 509.
Some of the ELMconfig files were re-written to disable Ice warning as the programmers were Russian and the warning can be on all the time in their climate. I hadn't realised the differences in their choices of firmware as it wasn't winter when I updated mine.
See here
http://www.fordownersclub.com/forums/topic/31287-guide-for-focus-mk2mk25-c-maxkuga-elm-327-cable-and-ff2-program/page-146
Does look like there are versions of ROM 509 which may well turn off the Ice warning, i.e. ROM 509 Full from the ELMconfig menu.
HEC ROM list is on page 147 of the ELMconfig thread btw.
