2011 Focus - Fuse Box Cover (Easy Question)
Total noob here, hoping a car expert could help out :)
My bluetooth has stopped working, so to begin I was going to try reseat or replace the fuse.
I've located the fuse box next to the engine but can't for the life of me remove the cover!
See images below:
post-63803-0-61762400-1426341927_thumb.j
post-63803-0-88481700-1426341930_thumb.j
I've tried pushing upwards on the small latch at the top left of the box and trying to pull, but it won't budge at all. The sides come loose but still seems like there is something holding it there. Is there a particular way I should be removing this?
Push it in.
but if bluetooth not working then theres no fuses there that will fix it.
Not sure what fuse to pull without looking,
or disconnect battery for a few minutes
post-59356-0-50094300-1426342652_thumb.j
  • 5 months later...
Hey Josh,
My bluetooth has failed me, did you manage to find a solution in the end. Was going to look at fuses, but looks like that could be a dead end...
