Led's ??
Just run an illuminated ignition ring to dome light..was gonna tap into it with some led strips..how many strips could I safely use ?
If you're using an LED in the dome light, a good 10 strips of 0.2 amp
No led in the dome light..just wanted some in footwells
So you're just using a regular filament bulb in the dome light?
In all honestly, it depends on the cable you Use. If you put a 5 amp fuse in and add the LEDs you'll be good till the fuse blows. Then you know you're at the maximum.
It the horn and interior light share a fuse then just go to the next closest fuse up
Oh ok..kinda bamboozling me..ha ha, bit of an idiot with electrics.
Just run ignition light pos & negative wire to connectors in dome light (reg bulb) then was gonna splice into them with led's..would that work ?
Thanks for ur help
Thanks for ur help
That's what I did with mine.. I ran an LED bulb then 2 metres of led strip cut into 4 for each footwell and it was fine. Still faded smoothly too
Brill..I'll give it a whirl.
Cheers
What led strips did you guys use?
Any links to them please.
Ian
I've just ordered some replacements which are mounted in an aluminium runner!! Tonnes better than the self adhesive ones I used before. I'll link after work
