Parking Lights.
Hi I have got a Kuga Titanium Sport X on a 64 plate with daylight running lights. I know the lights at the bottom of the bumper are front fog lights and indicators. There seems to be another light, can anyone tell me what it is as I think it's parking lights. If they are parking lights can anyone help me by telling me how to turn them on.
some of the kuga's come with passive cornering lights, with the headlights on does one side light up when the steering is turned ?
No not at the bottom. The passive corning light is built into the headlight. Thanks for replying.
can you snap a photo?
As I dont believe there are any other bulbs?
your car could have the standard cornering lights,sometimes these only activate when switched on in manual mode, does the buld in the extra light seam to be angled out?
Here's a photo of the bottom lights
post-65372-0-50434000-1431107915_thumb.j
I don't think that's a bulb in the middle of those
I don't know.
The way to be certain is to get under the car, take off the shield and check the wiring harnesses if you have three feeds it's a bulb for something or if it's too in one taped up it could be used for something, otherwise if there is only two then it's just the design
Ok
The light unit is the same on all mk 2 kugas apparently.
The middle one is where the drl goes for non led drl kuga s the light fitting punches out from behind.
Hope this helps
I think your right.
  • 4 years later...
That middle light is a sidelight w5w non led & should come on with headlights
