Petrol Smell
Strong smell of petrol at rear of car possibly from exhaust as no leaks any idea guys
I'm interested in this too as mine does the same.
Sent from my iPhone 5s.
sure theres no leaks? check the pipework for the evap canister.
Yep no leaks someone said it may be the bafflers are broken up in one of the boxes so when running that's why can smell it
So is it petrol fumes your smelling or exhaust gases?
It's petrol smell but like from the exhaust
could be that the engine is running rich?
It turned out to be the fuel canister purge pipe was adrift
Good to hear youve fixed it,
Hendy Ford found the problem today while looking at some other stuff for me so I'll keep checking just in case it happens again
Least it's fixed!
Where exactly would this fuel canister purge pipe be ?
I wouldn't know as it was left with ford over night I would think under car at rear by petrol tank
good guess, its behind fuel tank, black plastic canister.
Cheers. Probably hard enough to get to without going to a garage.
Easy enough as long as you got a jack and axle stands,
