Gears Wont Engage
OK I think I know what the issue is but thought I'd pick your brains before I get to work. I've got a 2000 reg 2.0 Focus and the other day it refused to go into gear and hasn't since. With the engine off and without using the clutch pedal it will quite happily flick through all gears but as soon as the clutch pedal is pressed down it refuses to go into any gear. This is the same with the engine on or off. I'm guessing it's a hydraulic issue so going to try bleeding it first and hope that works. Has anyone else had this issue and am I right to assume it's a hydraulic issue?
