Headlamp Masking
i checked Etis for headlamp masking and said that there is no need when i drive in europe, is that ok to drive without stickers on a 15 plate fiesta?
Solved by iantt
Do you have adaptive zenon lights?
If not then lens masks or beam adjusters are still required.
i dont have adaptive lights, from where i can get beam adjuster?
ok ty
seems a strange statement from ford etis, either needs headlamp lowering slightly or masking.
  • Solution
post-59356-0-23395400-1434197408_thumb.jpost-59356-0-43955100-1434197438_thumb.j
these are for the 2008-2013 fiesta, would have thought simular ones should have been available for later fiesta
ok thanks for all of your help guys ;)
In my 2010 Fiesta there were switches inside the headlight (in front of the bulb) to adjust the beam pattern for driving on the other side of the road. I haven't checked whether the 2012-2015 model has them or not.
Some newer Ford's have adaptable beam patterns via the menu in the vehicle which sets it correct for either side of the road
can you tell me where to look for it pls?
Wouldn't have a clue I'm afraid, can't find the thread I read it in. stoneys the best man to ask with his fancy 15 plate ;)
yes , but i dont have that on my menu :) , ill try to see if they have switches inside the headlamps thanks
i found it guys, there is no need for stickers or other things on my headlamps , the light is not like on normal headligts is just a stright line
anyway thanks all for help ;)
