Starting Problems
So now and again very rare I will go up to my escort mk6 1.8 ghia. And turn the key. There are lights on the dash and u get all power. However u don't hear the fuel pump cut in. Then you turn the key and there is no starter motor kicking in. U only hear a small click. Then more often not very. You are driving along and it just dies. Try turning it back on same happens as I I said up above no fuel pump no starter. Help
Also inside the engine by the firewall the only way I can describe it is as a piston. It's a cylinder shape and a metal rod that gets pushed inside when the key is turned on to the ignition. However when the problem happens and you turn the key u get dash lights but that pistion dosnt push in. What is this piston
I'm expecting it might be an imomobilser problem. How dose it work on this car ? As in what dose it cut of. If it cuts in will it stop the engine from turning over ?
If you need any information just ask
