Water In High Level Brake Light
2015 ST3 noticed a fair bit of water in the high level brake light.
taken it off and there is some kind of bung in it not sure what its for,taken this out and warmed the unit up with a hairdryer see if dries out overnight .
anyone else seen this ?
checked out my bros car (the same car) his is fine.
Hi my lad has st3 and his was leaking water in just take it back to where you got it from and they will put a new one on
Is or was the hose on correctly as the washer jet is part of the light.
Keep an eye on it when you refit it as the washer jet parts might age a crack or split in them inside the unit, if it happens again go take it to a dealer.
I had this happen to mine, dried it out and it happened again within days. Just go get it swapped, there must be a few faulty ones not sealed correctly or over tightened at factory hairline cracking the plastic
This is a common problem on the fiesta in general. I took mine off and 're sealed it and happy days no more water.
its ok saying you sealed it but i cant see anywhere to seal no cracks or anything in mine !
its a sealed unit other than the grey bung.
popped it in to my local dealer on Monday took one look and ordered new unit :D
