Fitting St Spoiler To Mk6
I have an ST spoiler to fit to my MK6 Zetec. I would prefer to have it fitted standard with the bolts. Any suggestions please? Preferably fitted by the bolts supplied.
Cheers
Is your car a 3 door? If you use the bolts then you should really seal all around the hole. Use as much sealant or tigerseal as possible as alot of people that retrofit an ST spoiler end up with leaks when sealant isnt used :)
