Drop In Outtage....
hey guys hope you can help....
when air con goes on revs drop v low then spike up over and over. can hear clicking on and off every 3 seconds.
idle valve changed, tps, throttle body cleaned. no leaks when air con on and its just been re charged with pressures checked.
shall i give idle valve a clean even though its fairly new. revs drop too low..much lower than normal or should i be looking at the compressor switch or air con relays?
Check the ac relay or idler pully
how do i check a relay? youtube?
