EGR valve
Good evening
Just wondering if anyone knows roughly how long it takes to change an EGR valve on a 2012 Focus 2.0 Tdci?
Will it have to have any sort of diagnostic done afterwards?
Thank you for any help
Should be under 2 hours at a garage. Bit longer if you're doing it yourself for the first time.
Ideally EGR adaptions should be reset using Forscan, but I doubt many people actually reset them.
Thank you TomsFocus 👍🏻
I’m assuming it’s the EGR valve as it runs perfectly when cold up until normal temperature is reached and then goes in to limp mode 😫
Forgive my ignorance, but why do some people run diagnostics after and others say not to worry?
Thank you for your help
