Adjusting Toe In On Ford Focus Mk2 Estate/wagon
Hello everybody! I'm a new member here and this is my first post. I tried to find a post abouts this but didn't, that's why I made this. First thing first, I'm from Sweden and I drive a black Ford Focus MK2 wagon, the 1.8 flexifuel one (from 2005). It's lowerd with FK Automotive coilovers and got some powerflex bushings etc.
My problem is that I got a massive toe in at the rear wheels. Is this adjustable or can you replace some bolts like camber bolts to fix this? Maybe some other adjustable arms? This problem is eating tires alot. If it's possible to get adjustable arms for the WAGON, where and which are the ones I need?
For now, here is my car on a swedish car forum: http://www.garaget.org/?car=292452
Thanks in advance!
(I hope I posted it right)
EDIT: Doesn't matter if it's for toe adjustment or camber, I just want to know if there is any adjustable arms / something similar for the Wagon/Estate
You need the tracking realigned.
I have been there one time and they did a 4 wheel alignment, but because of the "huge" drop in height, they said the adjusting was limited :/ is there any adjustable arms to help adjust the alignment which fit the wagon?
Hi welcome :)
Hi welcome :)
Thank you :)
So if I understood this correct. The first picture shows the original and adjustable arms for camber for the hatchback, right?
and the second picture is what I got on the wagon, and the part I want to replace with an adjustable one. The one for the hatchback, is it possible that it would fit the wagon?
picture 1
picture 2
You would need to check the length and fitment room behind the wheel, otherwise get some made for ur estate and then use a website called align my car to find your nearest hunter proalign garage so it can be adjusted out.
  • 2 months later...
Okey, for those looking for the same answer as I wanted, I tried to install new adjustable arms at the rear and it fits and works perfectly.
