Fan/aircon Query
Hi, i have a query. When i turn my fan on inside my car, the air con button is always lit & comes on aswell, i have to manually press the air con button to turn it off, each time i start the engine this air con is always on regardless if i've had it off previously, is this normal? I would of thought i had to press the air con button each time i wanted this on?
Ford Focus Zetec 1.8tdci - 58 plate
Matt
think it should only come on like that when you have got the direction set to windscreeen, (clears screen quicker with aircon on when misted up)
try it again with direction to vents or floor and see what happens
if set you the control some ware else it wont come on cant remember which
Just set the position 1 dot off the windscreen setting and then it shouldnt come on. Unfortunately that doesnt work though on my mk3 but did on my mk2 Cmax.
