Wing Mirror Puddle Lights
Hi Guys
On my wing mirrors I have some puddle lights on the underside.
Could somebody tell me how to access these bulbs so that I could replace them with LEDs to match the rest of my car?
Cheers
Move the mirror glass inwards with the controller, so that there is a gap on the outside edge of the mirror. Then very gently with your fingers pull the mirror glass away from its mounting. Once the glass is free, carefully support it, as it will have the wires to the heating element attached. You will see the bulb holder at the bottom of the mirror housing, can't remember if you just pull it or twist to remove. When you've changed your bulbs, line up the catches on the mirror glass on the mount and press back into place, taking care not to trap any wiring.post-33049-143820437962_thumb.jpg
Sent from my iPad using Ford OC mobile app
careful don't do what I done and snap a clip lol....you do need to be quite firm in pulling it out so don't be scared.
