Focus Mk2.5 Titanium.
I'm looking for some new ideas to do my focus. I've lowered it changed interior and exterior lights sprayed the alloys grills etc gloss black.
Any more ideas would be a great help as I'm stuck now. Lol.
How much are you looking to spend mate?
As much as the Mrs will allow. Lol.
No seriously I'm open to anything really. If it's something I have to save up for then I'll save for it.
It's a 1.6 petrol by the way.
Is that just the trim that sticks onto my current bumpers? Plus side skirts. How much would I be looking at for that?
Some ideas:
NGK Irridium spark plugs,
K&N57s-4000 induction kit,
Samco induction hose,
Thats about all can be done to engine unless upgrading to Piper cam shafts
Front tower strut brace
Braided brake lines with cross drilled and grooved discs
Team Hecko wind deflectors
ST Pod with ScanGaugeII installed
Dual reverse lighting
Sub and amp install
Speaker upgrade
10" rear flip down monitor
Cheers. Cant do an amp and sub install due to needing the boot for the buggy etc. 2 children do not travel light. Lol.
I'll have a mooch about on ebay see what I can find. What would I need for the dual reverse light?
Do you know where I can get a samco induction hose from? All the ones on ebay are for the St or rs.
Heres the dual reverse light guide has a shopping list with links: http://www.fordownersclub.com/forums/topic/29347-guide-fitting-second-reverse-light-ford-focus-mk25/#entry158997
Choice is yours regarding the sub,
But I've a buggy in the boot along with a 10" sub and two amps :lol:
Sub is off when kids in car of course
Guide: http://www.fordownersclub.com/forums/topic/63695-guide-fitting-custom-amp-sub-enclosure-mk2-mk25-focus-2005-2011/
Since you have kids in the back,
You may like to view my guide on fitting a 10" roof monitor great for long journeys,
Link: http://www.fordownersclub.com/forums/topic/67763-guide-fitting-flip-down-roof-monitor-dvd-to-focus-mk2-mk25/
Do you know where I can get a samco induction hose from? All the ones on eBay are for the St or rs.
Here's the hose mate,
It is a bit pricey but it is smooth flow and stronger than stock.
Link: http://www.ebay.co.uk/itm/220743040915
Cheers lenny. I'll take a look St those guides. What sort of benefits would I get with the samco hose?
Cheers lenny. I'll take a look at those guides. What sort of benefits would I get with the samco hose?
The stock hose is ribbed which creates restriction in airflow but its cheap to manufacture and bends easily so ford didn't have to spend time creating a bespoke hose, by just fitting this ribbed bendable hose.
The performance hose is smooth as glass on the inside, it also has sweeping bends resulting in absolutely zero resistance in air flow,
If this hose was fitted along with a K&N E-9289 Induction Filter
Link: http://www.ebay.co.uk/itm/K-N-E-9289-High-Performance-Replacement-Air-Filter-/131446800923?pt=LH_DefaultDomain_3&hash=item1e9ad7021b
You would have optimum non restrictive cold air induction while retaining the stock induction box.
It would result in smoother transition between gears as in the car holds a better momentum and 0-60 would be at its best possible unlock a few horses and optimise MPG,
Will also sound good on induction nice whoosh sound.
NGK iridium spark plugs would then be the icing on the cake for your engine all three items is the optimum performance its gonna get to be honest.
SciFiFantasyHorse_PowerhorsepowerjpgrZd3
Hi
Have you considered fitting a Eonon head unit instead of the factory unit?
I have done so and also fitted a reversing camera. The unit also has a DVD player as well as sat nav
Just thought DRL also look cool and aren't that expensive
Bigger wheels!
Hi
+1
DRL Fitting Guide Focus Mk2.5
http://www.fordownersclub.com/forums/topic/28999-guide-for-fitting-daytime-running-lights-focus-mk25/
Reverse Camera Fitting Mk2.5 Focus
http://www.fordownersclub.com/forums/topic/65470-guide-fitting-reverse-camera-mk25-focus-2008-2011/
The Eonon Headunit would be a straight swap without the need to fit an aftermarket double din fascia kit or iso adaptor looms,
You can recuperate funds by removing and selling the stock Bluetooth system and headunit,
See my guide here to removing those items however the aftermarket fascia section wouldn't be applicable if fitting an Eonon unit
http://www.fordownersclub.com/forums/topic/63689-guide-fitting-aftermarket-headunit-mk25-focus-2008-2011/
Discreet Dual Dash Cam DVR is also a good one
http://www.fordownersclub.com/forums/topic/65147-guide-fitting-dual-camera-dvr-system-focus-mk2-mk25/?p=438442
Here's a reference Guide if going for ZetecS kit
http://www.fordownersclub.com/forums/topic/33147-focus-zetec-s-kit-fitted/page__fromsearch__1
The kit bonds to existing panels,
Guide Fitting ZetecS Front Lip:
http://www.fordownersclub.com/forums/topic/32648-focus-zetec-s-front-skirt-lip-fitting-guide-pdf/
Guide Fitting ZetecS Rear Diffuser:
http://www.fordownersclub.com/forums/topic/32649-focus-zetec-s-rear-skirt-diffuser-fitting-guide-pdf/?p=255361
  • 1 month later...
how about st leather interior and wire them up so heated as well .powerfold mirrors .st rear spoiler.
