Fiesta Tdci (06)
I'm trying to get the rocker cover back on the head and I can't seem to get the 4 rubber seals that seal the injector ports sitting in the ports
Any tricks to doing it?
Thanks in advance
Big hammer
Better elaborate on that I supose, have you used new seals, as old ones expand over time and you will struggle, so seals on rocker cover, then grease the seals, place rocker cover in right general position and push down as far as it will go, then with block of wood or similar tap corners of cover down. Better if you got someone else pushing down on opposite side soit doesn't pop back out, you know its in properly when you can get the back 2 bolts in
A big hammer was my first idea :P
Yes I'm using new seals (was a engine swap so all injector seals were replaced)
Didn't think about greasing them up, would it be best to seat them in the injector ports first or on the rocker cover?
