Engine Management System
Hi all,
The engine management light come up on my mk 2 focus 07 plate, I've taken it to the garage and they say it's the pdf filter. They topped up the fluid needed for this and told me that once I've fueled up a few times it would go away. It has stayed on since. To resolve the problem could I remove the pdf filter and reset the ecu or is the pdf filter needed?
Do you know if the fault codes have been read and what they are? Not sure what the pdf filter is, I know its a file type on computers though :P
think he means DPF
The garage should have cleared the codes
