Low Coolant Level From New
Hi all - I have a 2015 Focus Zetec 1.6 TDCi 115ps 6spd 5dr, done less then 3000 miles to date. I opened the bonnet recently and noticed the coolant level is about 20mm below the minimum level marker. Should this be a cause for concern i.e do I need to top up immediately ? I've read elsewhere that regardless of the level that if it remains at the same level its nothing to worry about.
Anyone else noticed the same with their coolant level ?
Daniel
When the engine is cold I would top up to the minimum mark to give yourself a datum point ...drive a few hundred miles and check the level again when engine cold and on level ground ...if no movement I wouldn't worry but won't harm to keep an eye on it in future
thanks Jizzer - that a good idea about a datum ! I will keep an eye on it.
Daniel
As above top it up to minimum and keep an eye on it if it goes down again have it looked at but I suspect that on its presale inspection they just didn't top it up enough
