Remove Obd Cover / Lower Dash Cover Fiesta Mk7
Hi everyone,
I would like to replace my obd port by a dummy obd port.
But how do I remove the panel covering the port (see pictures) without damaging it? I only see one screw so I suppose it is a snap fit system?
post-67886-0-14087000-1439385168_thumb.jpost-67886-0-60946100-1439385173_thumb.j
If you mean the coin holder, you just squeeze the sides together and it will come forward.
You can see the tabs holding it at the back.
Hi there I know this is off topic my fiesta won't start what can it be it's ha new heater plugs and injectors filters
Fuel ?
Flat battery ?
Immobiliser issue ?
Probably get more of a response if you started a dedicated thread :)
Thanks for your reply.
Should I also remove the panel around the coin holder to get good access to the obd port?
It depends how much room you need to work with.
The OBD port just two tabs holding it in place each side of the port, so it should come out easy enough without taking any panels off.
