Egr Blanking
Hi guys does anyone know how much it costs, about, to blank off the egr valve on a 2007 cmax 1.6 tdci in a garage. I'm thinking of getting this done and I'm not very mechanically minded to do it myself. I was thinking of getting it Terra cleaned but I don't want to pay for that if its going to be false economy.
Doing it yourself - it's about a half hour job + £5 for the blanking plate - in a garage maybe £30 ?
See my 1.6TDCi EGR blanking guide here:
http://www.fordownersclub.com/forums/topic/42915-guide-fitting-egr-blanking-plate-16tdci-engine/
Also TerraClean would be worth doing however i dont believe the TerraClean process does anything to the engine oil sump contents,
I recommend using the AtomEx TotalFlush as saw in the EGR blanking guide to eliminate carbon deposits caused by the once active egr valve.
Link: http://www.xadoireland.ie/index.php?main_page=product_info&cPath=4&products_id=10
IMG_20150818_101223_zpse2zqtqbd_edit_143
IMG_20150818_101233_zpsel0vsuum_edit_143
If spending a few quid and planning to keep the vehicle for a few years you may consider DPF internal removal instead of TerraClean in order to prolong the life of the turbo and avoid a bill of replacing a blocked dpf in the future.
Image2317_edit_1439926412491_zpsr2jyhmie
AtomEx MultiClean for Diesel is also a great product for flushing through the fuel system,
Much cheaper than the TerraClean process with proven results unlike Redex it doesnt strip oil from parts,
AtomEx cleans and coats small imperfections with a thin ceramic protective coating.
Link: http://www.xadoireland.ie/index.php?main_page=product_info&cPath=3&products_id=26
IMG_20150717_091643_zpsoixfq7gn_edit_143
IMG_20150717_091611_zpsjxdfrmbq_edit_143
Considering the pound is very strong against the euro at present; its much cheaper to purchase above items from Xado Ireland rather than Xado UK save yourself over 10 pounds :)
After blanking the EGR valve you may also consider upgrading the induction filter to a Green Cotton Performance filter,
Because after blanking the egr; the engine sucks in up to 20% more clean air rather than waste gasses.
A smoother flowing filter provides the air at a faster rate as required which in turn increases your MPG, reduces turbo lag and lasts much longer than a stock filter before requiring change/replacement
Link to Guide discussion and discount code,
i believe your model takes a panel filter select correct model on the website linked here: http://www.fordownersclub.com/forums/topic/36783-green-cotton-performance-induction-filter-fitting-guide/
blank done it to mine makes huge difference turbo spools up quicker c-max is more driveable yes its panel filter that's next on my list when money allows :P
  • 4 weeks later...
Need to leave comment so I don't lose this thread when I'm on laptop later... :D
Remember that molten aluminium & water are explosive ! - Yes really.
The blank must be ferrous steel :)
Ah Yeh, I stuck a magnet from my phone cover near the blanking plate I have, :( no sticky :( I'll try again at some point with a proper magnet, but I'm not 100% sure it's good
  • 4 months later...
Can I do this to a 1.8 tdci and what benefits does it have??
thanks
And is the process the same as above??
benefits are all the same, accounting for the potential EML coming on, I would say its always worth doing. did it to my cmax and well worth the hassle!
Ok ace where do I get parts etc
ebay, stainless steel blanking plate is required, and you need a basic socket set
I got mine from here
http://stores.ebay.co.uk/Myldan-Auto-Design?_trksid=p2047675.l2563
  • 1 year later...
Hi there,
He can I get access to your eye blanking guide? I'm being told I don't have permission right now. It would be great to learn from your experience.
  • 4 weeks later...
Probably a silly question but some have gaskets and some are just plates, do you need a gasket for blanking off the egr? Getting it remapped in Jan so will get the EGR deleted
You can usually get away with using your current gasket when fitting the blank, but a new one should reduce the chance of any leaks so up to you really.
