head torques.
Hi all,im Steve and live in Spain. Had trouble with my 98 turbo diesel escort. Overheated quite badly due to cooling fan not working,due to poor connectoin in multi plug. Fixed fan problem but now got missfire on start up and hoses get very high pressure in them.I suspect head gasket, or are these heads prone to cracking???If so can the cracks be seen and obvious or are they hidden in the casting.Also ,does any body know the head tightening torques,so i have them when hopefully i put the engine back together!!
Thanks for all your help in advance.
7 - 5 - 1 - 3 - 9
10-4 - 2 - 6 - 8
new bolts: yes
Stage 1: tighten to 10Nm
Stage 2: tighten to 100Nm
Stage 3: wait 3 minutes
Stage 4: slacken off 360 degrees
Stage 5: tighten to 70Nm
stage 6: tighten 120 degrees
Hi Stef123 thanks for the head torques.Does anyone know if these heads are prone to cracking ???
Am i right in saying that the tool to remove the head bolts is a M12 Torx bit, as im having hell of a job to find anyone in Spain that sells them.Just to make sure when i finally find one.!!!!!
M12 torxs, i think your getting confused and hence why you cant find one.
i think it may be a spline bit you are reffering too? they generally go in sizes, M10,M12,M14,M16,M18 etc (there are also alot of other sizes)
Torx go like T40,T45,T50,T55,T60,T70 etc (again there are lots of other sizes)
a torx looks like a 6 point star shape where as a spline will have 12 points probably(this can vary but the triple square 12 point is the most common)
I think you should have another look. even post up a pic if you can?
have a look here - http://en.wikipedia.org/wiki/Torx
if you scroll down and have a look on the right hand side you will see a selection of drive types.
Yes ,your right there.No its definately a trox bit but does anyone know the size T ..what.Its very difficult trying to explain when i speak very little spanish and vise versa.Satisying when you do get it right tho.Managed to get a set of ball bearings i needed for a bearing in a wheel,how do you say Ball Bearing in spanish,LOL.
Will keep trying manana,lol.
do you have a bolt that you could measure the widest part of the torx head?i.e across 2 points of the star shape. if you could get the size i could tell you the size of torx bit. even if you only got a rough size
i think the size of torx bit you are looking for is a T70. i think its a T60 for the non turbo diesel
Thanks for that.
  • 5 weeks later...
Hi again,can anybody tell me the exact torx bit i need to remove the head.Have measyred across point to point and according to the chart size its a T70.measurment across is approx 15-16mm.Have been to the ford garage here and they have given me one but its marked as T80 and its too small.Does any one know the size please.
hmm weird.
a T70 is 15.5mm P to P so that should be the perfect fit. a T80 is 17.5mm P to P. according to what i have here it also says you need a T70. what is the measurement from P to P of the bit they gave you?
oops double post
Hooray, at last ive managed to locate a tool.The ford garage tool was too small even tho its marked as a T80!!!! Suddenly thought of a little workshop which is no more than a shack really.Went in and asked in my limited spanish ,and lo and behold he produced the correct tool from under a shelf in a grease soaked pot.He loaned it to me and didnt want anything for it,tho i shoved five euros in his top pocket with him protesting.The spanish are lovely people.
Lifted the head and found traces of water in number three cylinder.Gasket looks a bit black around fire ring in that area.Think good clean up and refitting will hopefully do the trick.
Thank you for all your help.Will post how it all goes,when ive got time to do it ,as very busy with work commitments at the mo.
