Fitting Drls
Hi guys I need to fit my DRLs but i got to connect a wire to the acc fuse according to my manual this is the air conditioning clutch is that correct and is it correct that's it's fuse number 27??? has any one else fitted these and how have you connected the wire to the fuse also how have you connected the wire to your headlight loom and I'm guessing this is the cables coming from the head light it's shelf cheers
Think acc in this case means accessory feed ?
Probably live switched ignition feed
I can think of no sane reason why DRLS should be connected to the air con :)
Lol I wouldn't know I nout about cars I just see the lights and wanted them lol do anyone have any clue which fuse the acc is then and if it's under bonnet or behind glove box cheers appreciate the help
I've noticed in the manual it's got 2 fuses that stat for DRLs
fuse 110, 10amp daytime running lamps ignition supply to lighting control switch
fuse 135, 20amp daytime running lamps
Can I use any of these to install my DRLs instead of the acc fuse which I dunno where that is
Wire them to the fuse box in engine bay, there is a relay that operates via ignition this is how I've done mine.
Do you know what fuse number and location you used mate cheers
