Still There Annoying Clunk/knocking😡😡😡
Hi all I have an annoying clunk knock from front of the car it's been there ages it's more noticeable going slowly over little bumps etc. I have changed the following both wishbones both drop links no broken springs and has passed MOT with no problems if I push on the car up and down can't hear anything any ideas anyone so annoying lovely car apart from that
It's a Y reg petrol focus estate sorry
Are they pattern parts or original ford, did you fit them yourself or did a garage do the work for you.
The anti roll bar D bushes are usually worth a look.
i had the same on my mk2 it was the strut bearing so i replaced the strut top mount and the bearing as well
Had the same 'clunk' on the nearside found out it was the top mount might be worth a look..?
Top mount for the suspension spring/shock u Mean also I might try disconnecting the anti roll bar drop links then drive a little see if noise is still there it's hard to diagnose been to 3 garages in total
yeah i had ford tell me it was a driveshaft but i could hear if the noise was from lower down or higher up near the mount if youre doing the mount replace the bearing and droplink
