Power Point Problems
I've a mk7. the power point next to the gear stick appears not to be working properly.
A while ago, it worked fine - could plug any accessory in like satnav / phone charger etc but now its not working. I put it down to potentially needing new fuse, and was looking to get a new one.
However, yesterday i plugged the tyre inflator in to check the pressures and to my surprise, it worked fine.
I haven't changed satnav or phone charger or anything so why are they all suddenly not working, but the tyre inflator still is?? i know the phone charger and satnav still work as use in van etc
Thanks in avance :)
Intermittent loose connection somewhere affecting the power to the socket by the sounds of it
Sometimes the contacts on the accessory in use become misshapen - try inserting & wiggling the plug of the accessory & see if it then works
ok will try this, thanks!
