Ford Focus 1.6 Diesel - Electrical Issues??
Hi Guys,
Since the last few weeks ive noticed various problems with my vehicle. This all stemmed from the garage repair work that i had done, attempting to fix my instrument Cluster.
Here are the issues im experiencing
  1. Defrost light does not work
  2. both indicators do not work
  3. rear wipers don't work (however, they do work when you initiate water spray)
  4. Side lights and full beams dont work (however, front headlights work fine
Can anyone point out what the issue may well be? I read up in some posts that the issue may well be with the fuse box, if so, what exactly am i looking for?
Any help would be hugely appreciated.
Regards,
Ati
It could be the fuse box otherwise known as the gem unit I'm not sure if you can test it though. However they are fairly cheap ie £30 or so on ebay just make sure you get a same or higher level than you currently have. It's literally a couple multi plugs and that's all
