Passenger Door Locked
I have problem with passenger door lock. Its locked and i cant open it with key, with remote or manually. Other doors work fine. I checked fuses. All seemed fine. Then i decided to take off door panel but i dont know how to release these door panel clips where door is against dashboard. Is there some known fix to this lock problem?
I managed to get door panel off. How i suppose to get door open inside the door. It seems maybe door lock motor is broke. So there have to be some other way to open door?
Disconnect the battery, it may cause a short to that door lock and move the mechanisum. Make sure you have the radio code first.
Check loom at hinge most likes u need remove wing an try fix broke wire otherwise u have to damage lock to open
