Trim Around The Windowscreen
Het guys, just wondering if you can help,
the seal around the top of my windowscreen keeps popping out, as seen in picture, i can pushh it back in but after 2-3 days it just pops out again. i assume it was from a poorly fitted window if the person before me had to replace it.
was thinking about putting some silicon underneath it then pushing it back in and hoping it holds, unless someone has a better idea?
post-68651-0-25934100-1442785214_thumb.j
damn, thats not good. surely that will allow water in?
ask a windscreen fitter to see if they can refit it for you?
It doesn't let any water in, not noticeably anyway.
Wow, that's just too much out of the frame! I would definitely consider visiting some window repair centre, this would probably need professional help (no offence to your skills ;) ) ... You may not have water inside, but it may leak down the pillars, under the roof lining, etc...and that's just not good :(
