1999 Focus Estate Heated Rear Window Only Half Working
Hi
Just wondered if anyone on here has had the same problem.
I have a 1999 focus estate, only problem being is the heated rear window is only half working/clearing.
Now I only use the car really for fishing and taking the dog out, but as you can imagine, only being able to see half out the rear window can be a bit of a pain.
Has anyone had the same problem?....and if so, how did you fix it?
Many thanks.
Rich
Probably a damaged track.
You can get repair kits from Halfords but they can be a fiddly job.
  • 3 months later...
I have just repaired the heated front windscreen it could be the same. There is a copper ribbon cable that tore off. I soldered a cable straight onto the windscreen then onto the copper ribbon.
