Eonon G2110z
Looking at getting on of these for my Focus MK2. I know I will need the fascia cover to make it double din rather then the larger ford size. Has anyone used one? will i also require a Double Din Cage?
http://www.amazon.co.uk/Eonon-G2110Z-Android-Operation-Bluetooth/dp/B00W3KN8GI
Looking for something?
We're sorry. The Web address you entered is not a functioning page on our site.
Go to Amazon.co.uk's Home Page
eonon do supply ford style head units that should simply fit straight into your existing fascia, i got one (from carjoying) that uses the oval style fascia in the facelift focus's. they also provide the square type one in the pre-facelift mk2 which i would assume you have.
http://www.carjoying.com/in-dash-gps-navigation-system/ford-head-units/joying-best-quad-core-high-vision-1024-600-plug-and-play-car-stereo-android-4-4-4-kitkat-double-din-7-inch-head-unit-gps-navigation-system-support-bluetooth-obd-airplay-for-iphone-free-external-mic.html
this is the style i have, which you could also fit if you get the mk2.5 fascia and mounting brakcets, unfortunately they dont do the square type one:
http://www.eonon.co.uk/Android-Car-GPS/GA5162F.html
to be honest carjoying is good but it has a whining sound when making calls using bluetooth. i think Eonon are UK based and hopefully has better quality.
I've been looking at those also. I like the MK2.5 style but shame its another £120 odd more!
Just be aware you are buying a budget level 7" Android tablet bolted onto a low quality amp. One of the units I've played with was exactly the same hardware internally as a Sumvision android tablet I also had lying around. Don't go in spending £300 expecting any level of quality.
