Epoxy Advice,urgent!
Hey Guys
Just joined to ask for advice,as stated in my introduction I have floated around here a bit for advice etc.
Here's my issue:
Recently bought my Ford Focus Lx TDCI 1.8 Mk2 from a leeds dealer.
Ran smooth for a week,until it suddenly went into Limp Home Mode after a trip to Skeggy,twice in fact,so allot of Revs etc.
This was accompanied by a Red Cog with the exclamation mark,has since gone never to return,but limp mode remains.
To solve this I tried a Glow Plug change and while doing this I snapped (Well not snapped completely) a plastic pipe,it's more split a little that snapped off.
Now it's slowly leaking yellow oil that originates from the container to the left of the Bonnet,Managed to stop the leak for now but when using revs it quickly starts leaking again,the stuff I'm using is rubbish.
So Need advice on the very best Epoxy to weld it tight,No way am I going to a garage when it's just a small crack in the plastic.
Thanks fellas,looking forward to any and all advice,love my new car,my first car I might add.
(Can't even test if the Glow plugs fixed the original problem lol,until this is fixed)
EDIT: forgot to mention that before posting I went ahead and ordered this on a whim
http://www.ebay.co.uk/itm/171853928430?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I find Araldite usually fixes most things :D
Thanks very much Mark,just ordered some now
Kudos
Did you make sure its oil resistant or you might end up redoing it in a few weeks time. Make sure you clean the area thoroughly as well.
I did fella
http://www.ebay.co.uk/itm/181686987828?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Sure hope this works,It's the hose coming from the Engine coolant Oil tankbefore it reaches the main engine block that has split (where the hose meets the hard plastic next to the dip stick).
Only had the car 2 weeks Q_Q
I've used it to reattach the radiator overflow pipe/nipple thingy on a rover 214 many moons ago so "should" be fine.
Soooo , New problem please shed knowledge all over me.
Snapped the + Battery terminal clamp bolt,,looked on ebay for a new one but no one selles these,under my search query : Ford Battery terminal bolt .
Maybe it has a specific term/Name I need to search with,anyone?
12063764_10204864942599966_2571267639879
Get an aftermarket battery clamp of the bay! :)
Maybe two if you're feeling Fancy
The obvious answer :) thank you good sir
Would have liked to keep the original though,but what does it matter in the end.
EDIT: Thanks just ordered 2,was feeling Fancy
Lets have a look at your hands, I reckon you have sausage fingers or your built like the hulk :lol:
:blink: lol
Just clumsy with the RAC socket wrench,first car and all
12036864_10204865618216856_1846223581334
Only kidding :lol:
