New Member With Focus Problems
Hi all fellow Ford owners,
Im rob from Kent, I would tell you about my mk2 focus but i doubt most of you will have that much time to get to the bottom of the issues im having with it......but for those of you still reading this; here goes.
*The airbag light stays on all the time, checked wiring but seems no loose wires anywhere so im not sure how to turn the :censored: thing off!!!!
* The engine warning light came on just before weekend, however the car appears to be running perfectly fine. I tried the trick of checking the diagnostics by holding the trip button down on the dials but this came back as NONE on the faults screen???? What could this have been? or is it a case of the previous owner changed a sensor and didnt reset the light with proper equipment?
* The heater cooling fan comes on after about 5mins of normal driving and comes on and off thereafter, then tempeture gauge is in the middle as normal so im a bit lost at why its doing this?
If you good people have taken the time to read all of this then i hope someone can shed some light on these issues. I know im new but i hope im not a big pain in the bum :whistling:
Hi welcome :)
Hi and welcome to FOC
You would be best off starting a new thread about your issues in the Focus forum. :)
Welcome to the site Robert! As stated above, you will get some help in the Focus forum as this is just for introductions.:)
You would to have a diagnostic check for fault codes. The airbag problem could be the result of something pushed under the seats and disturbing the wiring loom connections. Is your car high mileage?
