Ford 6000 Cd
Does every model have Bluetooth built in ??
nope.
and i think the bluetooth module is seperate to the stereo unit anyway.
The bluetooth module is seperate and if fitted will be located behind the glovebox (above the liner).
does it mean that I can buy one and connect it to my radio ??
The 6000CD stereo is rubbish. Just buy an aftermarket one with Bluetooth built in.
The Bluetooth/Voicecontrol system can be retrofitted without any problem. However You will need a lot more parts than only the module. The Bluetooth/Voicecontrol system contains the following parts:
* Bluetooth/Voicecontrol module.
* Mounting bracket for the module.
* Radio remote (stalk) with VOICE button.
* Microphone.
* Large model interior light surround (with a small grille to accommodate the microphone).
* Wiring loom for the Bluetooth/Voicecontrol system. Originally on cars with the Bluetooth/Voicecontrol system the wiring is fully integrated into the interior wiring loom behind the dashboard. For retrofitting the system Ford offers an accessoire wiring loom but this is quite expensive.
The Focus MK2 did have the old 1st generation Bluetooth/Voicecontrol system. Parts for this system are rare and expensive. The more common modules and wiring of the newer 2nd generation MK2.5 system are not compatible. Next to this both the 1st and 2nd Bluetooth/Voicecontrol system are no longer supported by Ford. Newer phone types can have compatibility issues and/or bugs.
in my opinion it is not worth both the effort and money to retrofit the Bluetooth/Voicecontrol system on a Focus MK2. A decent aftermarket system will be cheaper and have better functionality.
Or another option is install a Patrrot MKI9100 or MKI9200 kit.
Far cheaper and easier than sourcing/fitting the oem kit.
I want to able to listen to music of my phone as I believe, recording CD this days is rather stupid
According to what Wilco says it can be expensive so after market Radio with Bluetooth is a good idea. For 50 quit I can get decent Radio. Second option is just Bluetooth module that would receive Bluetooth from my phone
Look for a a2dp Bluetooth adapter on eBay that way you can use its buttons to change tracks without needing to touch your phone at all. I had one but bought the usb musicbox which has given my 6000cd USB port now
Agree with Daryl, bin the Ford unit, it's mediocre at best. A couple of weeks ago I swapped mine for a Kenwood, needed a face plate and connector kit, make sure that has the additional lead to allow the steering column controls to work. Got mine done at Halfrauds, took them 50 minutes which gave me enough time for a fatty burger'n'fries!
This is exactly what I'm looking for but how do I feed the audio to my radio ??
Aftermarket conversion kits come with iso adaptors to allow factory loom fit the aftermarket,
I've created a few guides may help;
Guide to changing headunit to aftermarket Mk2 & Mk2.5
http://www.fordownersclub.com/forums/topic/63689-guide-fitting-aftermarket-headunit-mk25-focus-2008-2011/
May also be interested in;
Reverse Camera Fitting Guide:
http://www.fordownersclub.com/forums/topic/65470-guide-fitting-reverse-camera-mk25-focus-2008-2011/
Custom 10" sub enclosure with removable amp panel:
http://www.fordownersclub.com/forums/topic/63695-guide-fitting-custom-amp-sub-enclosure-mk2-mk25-focus-2005-2011/
10" roof monitor install guide:
http://www.fordownersclub.com/forums/topic/67763-guide-fitting-flip-down-roof-monitor-dvd-to-focus-mk2-mk25/
My full list of Guides can be viewed here:
http://www.fordownersclub.com/forums/topic/68214-full-list-lennys-guides/
Thank you. This is awesome
no problem,
Any questions feel free to contact,
I've stripped out whole interior upgrading full audio entertainment system including TV tuner,Playstation and 4G WiFi,
Intalling Amazon Fire TV stick for Christmas😀
If interested in audio upgrade ive documented alot of research on my build thread;
Between Page 34 - Page 86
Link: http://www.fordownersclub.com/forums/topic/41443-taking-oval-to-blue-horizon-lennys-build-thread-2010-2015/page-34
I planned the perfect entertainment build,
Spent six months then researching best options for each item within there category of part
while purchasing and stock piling all items required.
Took a week off work stripped out interior and installed everything in the drive way across five days some sunny and some torrential 😀
