Rear Disk Conversion
Iv recantly baught a focus mk1 1.6 and da brakes could be so much better. I was looking at doing a rear disk conversion on it i was just wondering if anyone has done this and what is the best way of going about it
Hi mate i did this but mine was an upgrade on my old mk1.5 focus 2.0 esp. As i already had rear discs. I upgraded to full st170 brakes conversion all round. Front 300mm before: 258mm & rears 280mm before 253mm. So awesome stopping power.
I can tell you alot about my upgrade but wont waste your time so give you hints.
Only the 2.0 cc & some 1.8 cc engined models had rear discs. The rear discs are 280mm .
So you would need calipers ,carriers, splash shields/guards, hub/knuckles with abs sensors. Also need both handbrake cable , discs & pads. Best to go to breakers & look for a 2.0 zetec/ ghia. St170 upgrade is way better as its stopping power & look better behind alloys.
Yunii
  • 3 weeks later...
Don't forget to get a master cylinder. You'll also need a master cylinder from whichever route you go 2.0L Zetec/Ghia/ST170.
You'll have 'brake effort' issues if you upgrade your drums to discs without upgrading your master cylinder
I done the rear disc conversion on my 2001 1.6
Contrary to popular belief the rear discs do not improve stopping power - actually quite the opposite. I had mine checked on a brake roller and the power of the discs was less than that of the drums.
What you do gain is a greater efficiency to deal with dissipating heat - this is why i replaced mine. I had damaged the drum brakes through hard and repeated braking. Never had the issue with the discs.
As for master cylinder, it's the same pne for drums or discs - not the st170 setup though.
Cheers guy thats a great help i do road rallying and auto tests in the car and the drums just dont seem to cope with the abuse
