Focus 2.5 1.8 Tdci Blue Smoke
Hi.
Friend of mine has one of these on '57 plate at 75k. He says he gets blue smoke on cold engine start, e.g. in the morning.
He thinks it might be oil in the turbo but I think it's valve seals. He says it doesn't use any oil and it only started after it was overfilled by a garage (he dropped the oil and refilled it himself). He put 5-40 in it.
Any ideas?
Thanks,
D
Sent from my XT1039
Hi Jerzy
The Correct Oil for that engine/car is 5-30 fully synthetic
How many miles has your friend covered since the car was overfilled.
I would change the oil to the correct spec with a new filter
Also when was the fuel filter changed, Ford say 37500 miles, i and many of the other people on this board say 10,000 miles as its ony a fancy piece of filter paper in a canister
Hope this helps
Jamie
It does, thanks. Turned it he had 3 glow plugs open circuit!
Sent from my XT1039
Hi Jerzy
Gosh :-(
Did you get all four replaced
Did you get the oil changed again to the correct spec
Jamie
Hi
He's changed all four, I believe. I mentioned the oil but I don't think he intended to do anything about it (!) After all, oil isn't that important..... (!)
Thanks again
Sent from my XT1039
Hi Jerzy
I know what your trying to say about oil not being that important. but tbh if we put blood in you that does not match your original blood your body will start to shut down
Jamie
shocking statement about using the correct oil
I hope you know I was being sarcastic about the oil. I think he wasn't bothered as he was going to sell the car anyway but that sort of makes it worse.
Sent from my XT1039
not sure id be comfortable selling on a car that works but is potentially going to cause a lot of problems, id rank that up there with removing the EML light to fix a problem.
unless his trading it in to a dealer, since most of them a thieving so and so's id have less of a problem doing that ;) but still, some poor sod might end up with that mess and all the bills to do with it, I would be raging if someone did that to me.
Smoking first start up is a sign of leaking fuel injector as cylinder fills up over night.
If it's chucking out smoke I recommend blanking the egr value to prevent recirculation.
EGR is best blanked anyway regardless of smoke or not.
more discussion on that here:
http://www.fordownersclub.com/forums/topic/42915-guide-fitting-egr-blanking-plate-16tdci-engine/
Cheap diesel;
After changing its eh pigmentation can contain trace of sulphuric acid which will harden rubber over a period of time causing deterioration of seals; possible contributer 😕
Also an individual may choose a higher density oil in the event the engine begins to consume alot of the current grade.
that maybe so, but knowing what you know about the DV6TED4 engine, I'm not sure id want to make it any thicker than it already is!
that maybe so, but knowing what you know about the DV6TED4 engine, I'm not sure id want to make it any thicker than it already is! :)
Totally agree mate,
It's not somthing I would personally do on a modern turbo diesel.
what years and models had this engine fitted
Well....all of them, for the mk2 era anyway!
there are some variations of the DV6TED4 engine, some minor changes but its essentially the same beast,
the variant C model seems to have sorted out much of the problems
sarcastic or not. I aim to get to the point. but oil passageways are machined etc for a specific thickness of oil these days, :-)
Jamie
