Focus Fault Code C0700
Hi im getting the fault code C0700 when i plug my fault scanner in.
Can anyone tell me what this means?
Many thanks,
Mike
It's an odd code for a Ford - non Ford it's probably ABS related - '' left front solenoid ''
A proper Ford Diagnostic could tell you more
Digging about I found a bit of info.
Is your car an automatic?
P0700 for Ford shows as Transmission Control Module.
Basically it thinks there is an error in the transmission and throws a code.
if i reset it doesn't clear! i haven't really noticed any problems with the car, apart from it seems to make the clonk (abs test) randomly sometimes but has done that for the 3 years i have had it
yes its auto but its defiantly a C code not a P
If you read it as P0700 instead then-
Generic: Transmission Control System (MIL Request)
any ideas how to find whats wrong/sort it?
I've seen this on other Ford Forums - the OBD reader sees it as a C 0700 code . . . ?
That's not to say Clive's input is incorrect
The fact that the OP refers to a ABS '' clonk '' could be telling as this C 0700 code refers to an ABS solenoid issue ?
Any ideas where the solenoid is and how to test? Working on ABS is new to me! Cheers
