Wing Mirror Indicator Replacement Egg
2011 Focus Sport
Someone has bashed my drivers side wing mirror cracking the plastic black frame which I'm sure I can glue.
But the main damage is the entire indicator part has come out just leaving the bulb.
I've seen this as a replacement.
http://www.npautoparts.co.uk/car-maintenance-c2/lighting-c14/mirror-indicators-c298/ford-focus-mk-2-3-08-6-11-right-hand-o-s-clear-wing-mirror-indicator-p90368/s105506?utm_source=google&utm_medium=cpc&utm_term=replacement-ford-focus-mk-2-3-08-6-11-right-hand-o-s-clear-wing-mirror-msp3844-5029&utm_campaign=product%2Blisting%2Bads&gclid=CjwKEAiA1JuyBRCogJLz4J71kj0SJADsd6QRd2cX0zKYAj4Nem6UzkbhoR1caXgMQzpA5NRYIAy24RoCv97w_wcB
Is it the correct one and HOW simple is it to pit in.
post-70020-0-74192600-1447526817_thumb.j
No idea where the egg word came from!!!!
Predictive text?
2011 Focus Sport
I can't see a Ford finis number with that one, but it looks identical to this, http://www.fordpartsuk.com/shop/ford_focus_door_mirror_signal_lens_and_housing_rh_2007_f_1538489_c_683.htm
Assuming it's the same as the earlier fitment. You'll need to remove the mirror cover first, connect the wiring up; the indicator housing then will slot in the aperture and put the mirror cover back on .
You might want to look at Brigante's guide on the fitting the earlier type, http://www.fordownersclub.com/forums/tutorials/article/36-guide-to-fitting-wing-mirror-repeaters-to-mk2-focus-pre-facelift/
the principal should be the same on yours
