Heater Problems
As we might know, Ford Ka heaters arent the best in the world, but mine, only has cold, its in full hot and the only time I feel warmth is if I close all the vents, and drive for a long time, where eventually they warm up and as soon as I open them and turn the fan up, you feel a brief warmth before it goes cold again, friends have said that it could be a blockage in the pipes, even though me and a friend unblocked the cooling which stopped my car from overheating, but I suppose the heater pipes are blocked, since its winter, would it be better to sort it out now or later? Since the garage said I need a new coolant tank soon too due to a few cracked around where the cap is
Blocked pipes or matrix, or your thermostat has jammed open, if temp guage hardly moves then its the stat
I replaced the thermostat when I did the cooling, and temp switch too, I would say its a blockage too, just need to find time to give it a flush, and anyway, my Ka has no temperature gauge, just a speedometer and fuel gauge
ah yes, just an overtemp light
The garage said I needed a new temp switch since they said that could be why the fan doesn't turn on, it does now, but that was before I unblocked the cooling, like I mentioned it could just be a blockage in the heater matrixes
Try a reverse flush of the system, push any crap out the way it came in.
Just be aware that any flushing - either with water or chemical flushes could reveal any small holes in the system by unplugging them
