Later Engine
Focus C max
Hi and your question is?
My bad, pressed the wrong button! I'm thinking of fitting a later 2nd hand engine into my focus cmax and was wondering what pitfalls I would come up against? I have seen one and it is a 1.6tdci AV6Q 6007 BB with a six speed box. It is a complete unit with all these bits, Air con pump, Alternator, Cat DPF, Turbo manifold, Throttle bodies, air flow sensor, engine mounts, fuel pump, injectors, ECU, Engine wiring loom, Starter motor, Down pipe, Turbo, Engine cover, Sump, 6 Speed gearbox. It also comes with the gear cables and gear stick.
