Fiesta Bumper
Hi guys just wondering if the bumpers frount and rear off a fiesta st will fit my finesse mk6 as I want to upgrade to the st bumpers thanks guys
The front and rear bumpers can be swapped between 3&5 doors, prefacelift and facelift.
The sideskirts can be swapped between 3 doors. Spoilers & rear lights can be swapped between the same number of doors it came off
So I can put on the st side skirts and the front and rear bumpers also can I add the electric windows off the 3door st thanks
If your car is a 3 door then yes. You can also fit the spoiler.
Electric Windows you would have to check you have the wiring loom present in the car. you'd need to take the ST door wiring loom
Sent from my HTC One_M8 using Tapatalk
So if I take the st loom and electric window parts will it work thanks
Also do the parts need to be off a car the same year thank you
Body panels will fit anything from 2002-2008.
The window mechanism I'm not too sure about. If you don't find out by tonight I'll compare the part numbers on microcat
