[Mk2.5] 1.8 Tdci Water Temperature
can someone tell me the normal temperatures of the 1.8 TDCI in a Mk2.5 Focus?
But i mean the real temperature.. So not the gauge in the dash. I want the real temperature which you can read with a obd device..
Mine is (outside temp. ~0-5°C) at normal driving (60mph) between 65-75°C.
Was wondering if this is normal (Dash-gauge shows as usual steady 88°C.. thought a broken thermostat would affect the gauge).
Greetings
Real temp of what? coolant which is what the gauge on the dash attempts to display, or oil?
Coolant...
But not the gauge in the dash... thats not the real coolant temperature! its a calculated value and it's centered once it's at 88°C.
So you have to read the >real< coolant temperature via obd
Its a diesel so it will run cooler in this weather
But is 65-75 normal? It will never use the big coolant circle...
No is the answer, should keep warming( will take longer in winter) until the thermostat opens at around 88c , then cold radiator coolant will start to circulate, and thermostat will close again, reapeating this.
So, 88 to 90 normal
So, 88 to 90 normal
okay, so my thermostat seems to be broken..?
but i touched the upper water pipe to the coolant after about 10km.. it was freezing cold :blink:
btw: after 15-20km i have 60 °C and after 25km its always between 65-75.
after i drive 5km with 200-210kmh then it raises to 88°C and never goes higher. then it sinks to 65-75 when driving normal again
Dont know how long your car will take to get to get thermostat to open, the colder the temp of coolant before engine is started the longer and more km to warm up.
An example is my car, I have petrol 1.0 ecoboost and with outside temp of 10c it takes 7 miles(11km? ) to get to 90c, diesels normally take longer
Does sound like thermostat is opening early still.
So this should be changed in future...
Easy to change on the 1.8 tdci?
Yep , easy enough. 3 bolts or screws holding housing on
Great thanks!
