Does New Instrument Panel Need To Be Programmed - Ford Focus 2006
Hi all
I am going to replace the instrument panel for ford focus 1.6 TDCI 2006. I am wondering if it needs to be prgrammed? I am going to replace it with a used one, of the same type.
Are there more things i need to be thinking of when replacing it?
Picture of the instrument panel in the car is attached the post.
post-70862-0-99707800-1451398549_thumb.j
The cluster on your car is integral to the immobiliser system so will need coding with IDS.
You will also need to get the mileage matched to your original reading but be aware that it may not be possible to wind mileage back, only forwwards.
Thank you for your answer. I am wondering how i can do it by myself. What do i need and how difficult it is. What is IDS by the way?
Ids is the Ford software and you will need the vcm interface too. Not cheap to buy but the only way you can change the cluster display is with it. Otherwise car won't start and display won't work
Sent from my SM-G920F using Tapatalk
Easier to buy a new ECU, clocks, key transponder ring, key, locks
That way you shouldn't need to code anything
